RTrider's avatar
RTrider
Grey water tank sludge
Helping a friend with her grey water tank issues.
2009 36 ft. Motorcoach
The tank drains very slowly. About 4 months ago we drained the tank as best we could and then took apart the slide valve and connecting piping to the tank, leaving the tank outlet open. Sludge came out and because we were in a campground we could not let too much drain out as other units were next door. Put things back together and filled the tank and did some direct drains and all improved quite a bit.
4 months later, now back in the same situation. This time she is in an area she can dump the grey water tank onto the ground (at a farm). T
Two questions:
1) Any suggestions on how to flush the tank other than a hose directly into the tank through the exposed outlet when we take the piping apart. I am a little shy of using a pressure washer into the tank.
2) How can she prevent the sludge build up. She lives the coach full time and does not put anything but dish water and shower water into the grey tank. She does not have a dishwasher or clothes washer in the coach.
Any suggestions will be well received.
  • 2oldman wrote:
    Sounds like the tank needs a thorough cleaning.. but I don't know how that's done.
    There is a national franchise operation called All Pro Water Flow that cleans both gray and black tanks with a pressure washer and specially designed small nozzles. We had ours down several years ago when we were experiencing what the OP has reported in this thread. It fixed us up, although we do need to have it done again.
    Those of us who full-time in our RVs and have washer/dryers really can't keep the gray tank valve closed all the time unless we wish to risk washing machine overflow accidents. I don't mind having the tanks cleaned every couple of years as the price I pay for this convenience.
  • Try adding a cup of liquid dishwasher detergent and a gallon of hot water. Ride around for awhile and dump. Repeat as needed.
