benjaminfoster
Mar 07, 2026Explorer III
I haven’t seen the exact diagram for that model, but sometimes the thermostat burnout is caused by incorrect element wiring or a bad high-limit switch. If you can’t find a manual online, you might try checking inside the access panel and tracing where the supply lines go to the thermostats/elements that often helps piece it together.
