MrWizard
Aug 30, 2016Moderator
What is the input power voltage?
Is it 12v or 48v
But I don't think you can use it
Grid tie inverters require line input ac power to be present before they will turn on
Normally connected to high voltage solar and only create ac power when utilty is present
They turn off aka disconnect when utilty power goes out
Safety to prevent the inverter from energizing the lines and killing a lineman working on the outage
Is it 12v or 48v
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
