kg1d_dxExplorerDec 04, 2015Ground faultI have a ground fault outlet on each circuit in my coach, but I keep frying the one in the bathroom. Happens when the circuit is over loaded usually by my wife's hair dryer. My question is why does th...Show More
tenbearExplorerDec 04, 2015The obvious test is to plug the dryer into another circuit that is protected by a different GFI. If the GFI fries or pops, the dryer has a problem.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
Related Contentground faultGround Faults Circuits are offIs one of your tie down tabs grounded?Ground Fault Isolators (GFI's)Ground fault alarm
