Winged_One's avatar
Winged_One
Ground-Neutral Bond clarification needed.
I need a quick clarification on using a Ground-Neutral Bonded (GNB) plug on a Yamaha 3000ISEB (or any inverter type really). Not sure I am understanding something.
When making the GNB plug, does the wire from the trailer have to pass through this GNB plug and into the generator for it to work?
Reading elsewhere on the net, I get the feeling that if I make a GNB for one of the 20 amp receptacles, plug it in, then all my other receptacles (20 amp and 30 amp respectively), will also be bonded. True?
  • Winged One wrote:
    If you say so.
    ken white wrote:
    enblethen wrote:
    What I did was got a spare male connector. Jumpered the ground to the neutral pins. I then plug it into a 15/20 amp receptacle on the genset. (Honda)
    Same thing I did...
    LOL...
  • ken white wrote:
    Winged One wrote:
    If you say so.
    ken white wrote:
    Same thing I did...
    LOL...
    That doesn't answer whether the cord needed to be plugged through the spare male connector, does it?
  • wnjj's avatar
    wnjj
    Explorer II
    Winged One wrote:
    ken white wrote:
    Winged One wrote:
    If you say so.
    ken white wrote:
    Same thing I did...
    LOL...
    It kind of does. There's no mention of a spare female connector so to me it implies the male connector in one receptacle and the cord in the other.
    The bond plug has no cord and carries no power.
    Your RV cord plugs into the other outlet.
  • ken white wrote:
    Same thing I did...
    me to.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
