Dusty_R
Sep 30, 2013Explorer
MrWizard wrote:
all 12vdc circuits in the RV
have 2 wires
both the positive and the negative
rv house circuits, do NOT use the frame grounding method that Vehicles use
insde the converter you will find a NEGATIVE bus
it will NOT be grounded to the RV frame
yes the battery is, but the 12v circuits are wired with 2 wires from the converter/fuse panel
its possible you will find all the Negatives, fastened/connected together inside or behind the converter
Somewhere that NEGATIVE is fasten/hooked to the battery, most likely through the frame, or none of the 12 volt would work.
Dusty
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
