BurbMan
Sep 30, 2013Explorer III
All of the above...Yes, there is a negative bus in the converter, but it connects to the frame and uses that as the path of (-) on the battery. So there is nothing wrong with grounding to the frame IF you can fine frame to ground to...in a stick/tin or fiberglas RV the frame only runs around the bottom...
Depends on where you are planning to install the lights. If inside then plan on running a 2-wire set from the converter so you have a return path for ground. If for example you were adding a light under the RV for the steps, you could could ground right to the frame.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
