DryCamper11
Sep 30, 2013Explorer
tenbear wrote:
Most of the negative wires in the house are returned to the power distribution box (the box that contains the power distribution panel), however my converter is grounded to the frame.
I can't think of any electrical reason for this, and so I think the negatives are returned to the power distribution box because there is no metal frame in the house, all plastic and wood.
In a vehicle, the frame is almost always nearby. In RVs, the lights are often mounted to luan roof plywood, to plastic or to insulation of some sort. The light manufacturers recognize this, so they supply a ground and a +12v wire, while automobile lights usually supply only the +12v wire (and expect you to run a ground wire to the light frame if you don't mount the light to the vehicle frame.
AFAIK, that's the only reason for the difference. On my RV, there's a ground distribution system for lights and devices (refrigerator, etc.), which goes back to the DC panel and from there the ground goes to the frame.
