MEXICOWANDERER
Sep 30, 2013Explorer
NEC? Low voltage DC? Damn I must have Alzheimer's disease. Personally I bond a trailer frame with ONE gauge cable and a 3/8" stainless bolt and stainless Stover lock nut and external tooth lock-washer. Then I smother it with corrosion preventative.
It is poor practice to "ground" small accessories like lights to a trailer skin. Instead, I run the wires to a ground BUSS (Go to home depot and buy the tin plated aluminum ground buss bar to do this). I use two or three in a medium size rig, strategically placed. Then I run an EIGHT gauge yellow wire from the buss bar to the rig's frame. Same principle only I use 1/4" stainless steel bolts. I use YELLOW FOR 12 volt GROUND not black. Black is reserved for 120vac HOT.
The 120vac green earth ground service cord "plug in" from the power pedestal should NEVER be joined to anything except ground circuits leading to 120vac accessories. In short shore power grounds should be GREEN and they should be kept STRICTLY isolated from the frame.
