schlep1967
May 01, 2020Nomad
If you have a enough extra slack, the easiest way would be to cut the red line right behind the crimp ring, disconnect it from the sink line and walk into the hardware store with it in your hand. If you don't have a pex crimp tool you will want to buy a "sharkbite" fitting to get you from the half inch red/pex line to the female fitting.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
