jdc1
May 01, 2020Explorer II
Lynnmor wrote:
I saw this post somewhere before.
Install a PEX stop valve that can connect to supply lines. This will simplify the connection and give you the ability to service the faucet without shutting down the entire RV.
Yep. They even have a simplified "Shark Bite" angle stop for this, if you don't have the PEX crimper. Any time you replace a part like this, use brass, SS or copper fittings. Get rid of the plastic, little by little.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
