Old-Biscuit
Aug 10, 2013Explorer III
Zinc reacts the quickest providing the most protection BUT haven't seen any 'zinc' rods for rv water heaters.
Magnesium reacts quicker than aluminum BUT can react to bacteria in water and cause a sulfur smell
Aluminum is slowest reaction which means rod lasts longer and might not provide as much protection. Also deposits can build up on aluminum rod making it harder to remove thru drain hole.
Most rods available are aluminum & magnesium alloy.
Anode rods are available for Atwood Brand water heaters BUT they are NOT needed, MFG. doesn't recommend them.
Suburban Brand water heaters use an anode rod (9" X 3/4" some are 9 1/2" X 3/4") and are aluminum or magnesium.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
