BFL13
Jul 09, 2015Explorer II
New snag. When the controller is in Float, it will still provide the amps to run loads and keep the battery up.
But with the batts full and voltage at 13.2, when I turn on small loads the amps on the Trimetric go negative (charging light also goes out) and then after a while the amps come back and go positive and the charging light comes back on. The controller stays in Float for these small loads (laptop, turn on a light or two, etc)
The usual thing with those three- stage converters is that they will be in 13.2 with no activity, but if you start using your 12v things, they jump back to the standard 13.6v level. I think I see why.
So I reset the Float voltage to 13.6 and now small loads still cause a short duration drop in the amps to the battery, but the amps stay positive and the charging light stays on.
I think Mex recommended 13.2 thinking it would be a "storage" rather than a "still camping using 12v stuff" situation. Anyway, I am now leaving it at 13.6v and we'll see how that works.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
