Itinerant1
Jan 08, 2018Explorer
Magnum remote (ME-ARC 50) connected to the Magnum inverter/ charger.
Solar- Magnum PT100 charge controller connected to the inverter/ charger.
Scrolling through the menus.
DC Meters
DC Volts shows voltage from the battery bank connected to the inverter.
DC Amps meter shows current going in or out of the battery.
AC Meters
AC voltage output either inverting or passing through from grid/ generator.
Load Amps meter displays the total AC current delivered to the loads on the inverter’s AC output terminals. A positive (+) Load Amps value indicates power is being pulled from the inverter to run an AC load—either using the batteries in Inverter mode, or from the AC input source in Standby mode.
Input Amps meter displays the total AC amps being used by the inverter for charging and for any load connected to the output of the inverter.
Inv/Chg Amps menu displays the inverter or charger amps and is shown as an AC value. A negative (–) amps reading indicates the inverter is powering the inverter loads, and the batteries are discharging (inverter amps). A positive (+) amps reading indicates the inverter is using the AC input source to charge the batteries (charger amps).
PT charge contoller menu
Charging status -Bulk Charging, Float Charging, Sleeping
Faults (if present)
Power status
Relay status
Battery amps
Power to Batteries-
Now: This display shows the power out of the PT controller occurring now (in Watts).
Life: This display shows the total power out of the controller since it was installed (shown in Megawatt-hours or MWh).
PT Ground faults
PT Data (past 255 days)- KWH Harvest total, Max PV, Max battery volts, Min battery volts, On/Work time, Max power.
PT Faults History
LiFePo4 Battery Management System connected to a 7" display showsz live time readings.
1st screen- pack voltage, pack current (amps being used or charging), pack capacity (state of charge in percentage), Min/Max Cell Voltage, Alarms and Warnings.
2nd screen- shows individual cell voltage & individual cell temps,5 batteries x 4 cells = 20 cells
DC Meters
AC Meters
Faults (if present)
Power status
Relay status
Battery amps
Power to Batteries-
PT Ground faults
PT Faults History
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
