MrWizard's avatar
MrWizard
Moderator
Apr 15, 2016
Hall Effect DC amp meter
eBay has some new hall effect sensor meters
rating -50 amp to +50 amp
reads charge discharge
no counting or anything
these are similar to the 70amp ones that were available 6 or 7 yrs ago
with added Voltage display function
for some uses were the load is less than 50amps, these can be used as replacements or New installs
current sensing hall effect meter
  • You have to go down the page and in the specs it says +/- 100 Amps
  • RoyB's avatar
    RoyB
    Explorer II
    Was looking at the specs I didn't see anything to tell which direction the current was flowing - was hoping to see a minus(-) symbol...
    ALso wonder what you do to make it read voltage.. Don't see any button on front frame...
    Roy Ken
  • just FYI, the larger the range, the less precise the measurement. so a 100a meter on a 20a fused circuit is going to be rather useless (IMHO)
  • RoyB's avatar
    RoyB
    Explorer II
    Hey thanks guys - Just in time too... I need three... I believe I will go with AMAZON PRIME... Hope that one reads both directions with a minus (-) - didn't read up on it yet... Last time I ordered from EBAY I ran into a couple of problems with PAYPAL... I guess I haven't used as much as I should have...
    3/4-inch hole is just great...
    I will use something from LOWES ELCETRICAL PVC Boxes to hold the COIL...
    Thanks for the posts...
    Of Course I want one of those multi function screen meters to on here a week or so ago... One of those had a settable alarm function too...
    They pretty neat as well
    Even MEX likes these prices...
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
