- Kevin_ToddExplorerBet all we got on our pinnacle is the label. No plastic hood on the rear cap.
- We have the Furrion 3 camera system. The rear camera is below the roof line, the fiver is 42' long and our pickup has an 8' bed. No problems with wireless reception.
BTW, I think the poster that mentioned Fusion meant the factory Furrion connector that is on a lot of the newer rigs. - waynefiExplorer III just bought a Haloview MC7108 wireless camera. Used it on one trip, and it works well.
It is on 22 ft trailer, slightly below roof line, and I get a strong signal..
My trailer was pre-wired for Furrion. That means that there was a plastic hood high on the back of the trailer which covered some mounting screws and a 12 volt plug. I bought Haloviews mounting bracket for pre wired RVs, which is a bracket that fits the mounting holes and a cable that adapts Haloviews plug to Furrion’s.
The only problem I have is that the plug is too long to stuff into the wall, so I am left with a coil of wire outside. - agesilausExplorer IIIWhat is a Fusion connector? Is that one of those that you connect a wire to an existing wire, sort of on the side of the existing wire? Hard to describe and searching Amazon for Fusion connector just pulls up a bunch of connector kits. None of which seem to apply.
Using google pulls up fiber optic connectors - RICK-ards_RedExplorerI have an older Haloview wireless camera on the back of my 30 ft TT with the antenna below the roof line of the trailer. It works great every year with clear pictures and sound in the truck cab Got the adapter plug to hook into the Fusion connector from Amazon.
- agesilausExplorer IIIOurs works fine on the back of our 30 ft AF TT, maybe 40 ft from the truck cab. And actually I think I carried the camera 30 or 40 ft behind the TT and still got an image. I assume your has the same transmitter but have not way to tell.
I'm thinking of rigging up a hard wire 12V system, should not be hard I just need a compatible male plug, - Kevin_ToddExplorerThe system I'm considering gets camera power from the 12v wiring on the coach. I'm concerned about the wireless connectivity. The byte tango system looks to be fairly new,but my mounting options are forcing ne to either mount the rear camera with the antenna below the roofline or mount the bracket on top of the rear cap. Just wondering if anyone uses a rear camera that is wireless mounted with the antenna below the roofline.
- agesilausExplorer IIIWe have the color system and it has revolutionized my hookup process. I stick the magnetic camera on top and slightly in front of the of the truck hitch ball and can back up and connect the hitch my myself. I painted the RV receiver white to make it more visible on the camera. Orange might be better. Glare can make this harder.
Be aware that the camera battery only has a six hour life, it has an external battery pack that extends that. But you have to remember to take those off and recharge them every night.
Also the camera and battery fell off the steel plate once and broke the antenna. That made me leery of leaving them attached. I'm say they need some more secure attachment, a lanyard maybe.
But all in all I'm happy with the system just for the hookups.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
