- Dave_H_MExplorer IIYep I have a sliding window that usually has finger smudges on it from opening and closing it. once in a while I have to likc my finger to get enough friction. :B
- mgirardoExplorerWe had that happen with the most used sliding Window in our Class C. The handle was just held in place by friction. There was a piece of rubber between the handle and the glass. We'd put the handle back on and it would fall off again in a day or two. We learned to just slide the window open from the glass. We'd just put our hand on the glass and slide. The window still locked as the lock was not part of the handle.
-Michael - ol_Bombero-JCExplorer
wa8yxm wrote:
I like goop too.
this is a sliding window,.. so if you had to you could use a suction cup device to slide it. the issue is really that the handle is often also the locking device.
So long as the slider is on the INSIDSE a small length of dowel rod or hakf or quarter round (i'd use quarter) layed in the track works well
or drill STRAIGHT down and drop in a bolt or pin Drop in means lift out,.
IMO - my "guess" is.....it's not a security issue, but how to get hold of the window to slide it.
Security (only) options are easy - as in suggestions offered..
If the OP could elaborate - solutions offered might be better?
What's a "destination trlr"? (Why did we need to know that?)
Normal recreation trlr (RV)? Mobile home?
Suggest the "goop" method (doubtful) or JB Weld for metal to metal.
It's a sticky situation!..:W
~ - JRscoobyExplorer IIAs to locking the window. The sliding door at home, I drop a wooden rod in the track at the bottom. But I use a cheap bar clamp mounted near the top, to push between door and frame. With that in place no shake in the door.
- wa8yxmExplorer IIII like goop too.
or drill STRAIGHT down and drop in a bolt or pin Drop in means lift out,. - midnightsadieExplorer IIclean the area real good get any oily stuff off the glass .I,d try a little goop sealant.
- BFL13Explorer II
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
