rtate wrote:
smkettner wrote:
rtate wrote:
Ok. I give up. I will stick with my little Honda 2000.
Was it realistic to think 2000 watts can be replaced by 45 watts? 97% reduction in power.
Post more details of your camping style and we can set you up with something that will really work.
I assume with a single Honda 2000 you are just charging the battery and running the microwave or possible a hair dryer. It would be sad to run the Honda to charge a cell phone or watch a movie.
Even if sticking to the generator it might be a good time to review if your battery charging system is set up to do a proper fast charge to minimize run time.
If I cant run my air conditioner, microwave, hair dryer, and electric coffee pot with the Harbor Freight set up, then its not worth spending the $120.
At a min a microwave will require 800W (small 700W versions) upwards of 1600W (large 1500W).. Neither will a small battery system or 45W solar panel support this kind of load.
It would take 4 GC batteries plus several hundred watts of solar AND still need a generator to make that work.
Large high wattage items are best operated from a gen and low wattage items can work well with a modest solar/battery system..
