Snowman9000's avatar
Snowman9000
Harbor Freight Mexcharger Question
Prior to going on a recent dry camping trip, I tested my new Mexicowanderer HF Charger. 2/10/55 or whatever it is. If I understand it, for regular charging, it should be set at 10 amps and Start, which should yield about 17-18 amps and no tapering.
The battery was at 12.3v, so not deeply discharged, when I tried it. It put out the 17 amps, but the voltage was only 13.1. Is that how it works? I thought the voltage was going to be in the upper 14's. I didn't try it on the trip, I left it home due to space constraints, given the above performance.
