Locky
Jan 30, 2014Explorer
Here are the specs on the Champion Inverter:
2000 Watt Champion Inverter Generator
Delivers consistent power flow to accommodate sensitive electronics
Eco mode conserves fuel on reduced loads
Connect with another identical unit to double output
Push-to-Reset Circuit Breakers
Comes Fully assembles
Two year limited warranty
Easy Pull recoil start
Low Oil shut off
CARB approved
Lightweight
True sine-wave technology delivers pure, smooth waveform power for peak performance from all your electronics. Champion Inverter Generators are rated for 1,600 watts with a maximum load of 2,000 watts. Eco mode idles to conserve fuel on reduced loads. Stackable frame and parallel connector doubles power output when linked with an identical Champion 2,000-watt Inverter Generator. Includes a single 14-amp, 120-volt duplex & 12-volt dc with 12-volt battery charging cables. Overload protection and low-oil shut-off. 53dBA at 23 ft. The 2000 has a 80cc Champion single cylinder, 4 stroke OHV engine with a 1-gallon fuel tank and can run 9-1/2 hours at 25%. CARB approved in all 50 States.
19.3"H x 13.2"W x 16.3"D.
Wt: 48 lbs.
Available:
2,000-Watt Inverter Generator
Parallel Cable Kit - connector includes one L5-30 and one 30-amp RV receptacle.
Low Oil shut off
CARB approved
Lightweight
Wt: 48 lbs.
Available:
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
