I have a 15,000 BTU AC on my class C, recently it started popping my breaker at start up, maybe it is because it is i the 100's or because I use a 50' 30Amp cord. All equipment is well maintained and ...
BTW you did not say what all you had on when trying to start the a/c hot water heater, coffee pot, converter, etc.....with converter and a/c on in our unit, that can be as much as 21 amps....make sure hot water heater electric 110 is off.....as that could be what is setting off the break.....do you use a surge protector to check the volts and amps?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
