I have a 15,000 BTU AC on my class C, recently it started popping my breaker at start up, maybe it is because it is i the 100's or because I use a 50' 30Amp cord. All equipment is well maintained and ...
If your using the proper size generatior you should not need on at all. That being said they are used on compressors that are hard to start regardless if used on a generator or pluged in. The hard starts were not developed just for generator service. They are used in home ac units as well. If you need a hard start to run your compressor at some point in the future you could be looking at replacing a compressor.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
