N7SJN's avatar
N7SJN
Hard water spot removal from outside RV
Have been parked where a sprinkler has been hitting the side of our rig and the spots have built up. I have tried the vinegar trick but to no avail, so I hope some one has had success with a easy to apply product.
If this isn't the right forum I would appreciate it being moved.
  • I used CLR on a nylon mesh foam pad and it worked without much scrubbing.
  • When I put some redmax pro on the cap of my 5er, had some tough water spots on some windows. I found the white 3m scrub pad and barkeepers friend did the best job at removing them.
  • General hard water spots I like the Meguiars cleaner wax. If the spots are hard water iron deposits I find mixing 1/3 cup of Iron Out to a 10 quart pail of warm water works well.
  • I'd recommend Meguiars products. They sell a water spot remover. I haven't used that particular product, but I've used other products from them and been satisfied. Auto supply stores generally carry Meguiars, as well as Amazon.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
