SoundGuy
May 01, 2016Explorer
DutchmenSport wrote:
So when I went to get a replacement, I decided I STILL did not want a hard wired one, for exactly the same reason you've mentioned... if it goes bad, you have no alternative but to sit with no power until you can either rig something else up or get a replacement.
Well that's simply not true at all - any hard wire version EMS or surge protector can be installed using standard 30 amp or 50 amp connectors, in which case if any need to remove it arises it takes but seconds.
While the portable versions are certainly the easiest for most people to use the PI hard wire EMS models offer several advantages ...
First, they're field serviceable, meaning if it fails it need not be returned to the manufacturer for repair as PI will simply mail you the parts required.
Secondly, delay for the hard wire model can be set at either 15" or 136" whereas the portable PI units are fixed at 136".
Third, the display for the PI hard wire models can be placed in any convenient location where it's easy to read, with the portable model you have to be where the unit is located in order to see the display.
Fourth, theft with a hard wire model is obviously not an issue, 'though as already pointed out this problem can be mitigated as already mentioned by placing the portable unit not at the campsite power post but next to the trailer.
Fifth, personal experience with my own Progressive EMS has proven that they're not always as accurately calibrated as they should be ... with a hard wire model one can easily recalibrate against a DVM of known calibration but a portable unit would have to be returned to the manufacturer for recalibration.
My first was a portable TRC Surge Guard but last year I upgraded to a Progressive Industries EMS-HW30C for all the reasons above.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
