hyfyve
Jan 19, 2015Explorer
wolfe10 wrote:
Two questions:
I don't understand the 120 VAC OUT from the converter to A/C, refrig, water heater
Also, what you label a "switch" could be a switch, or if the inverter has a pass through feature, a sub-panel (better).
Wolfe, I am just assuming if I didn't have shore power and had to run on the inverter then if I have the high wattage devices running through the switch the inverter wouldn't handle it, by leaving those items running only when shore power is connected then I should be OK, but please if I am wrong someone let me know, just want to make sure I do this properly.
BFL13 wrote:
Change "converter" to "power centre" The converter is just the part of the power centre that makes 120v into 12v. It has no 120v output.
Fixed thanks
