wolfe10
Jan 20, 2015Explorer
Yes, like most higher end inverters and inverter chargers, this one has the pass through feature: http://www.marinepartssource.com/newdetails.asp?mfgno=806-1810&pnumber=XT8061810&mfg=XANTREX&desc=Pro%20Series%201800W%2012V%20Inverter%20w/AC%20Pass%20Through
Using an inverter with this feature and routing inverter output to a sub-panel for those things you want to be able to run on on the inverter allows a very electrically "correct" installation. Where both hot and neutral for those circuits are on the sub panel.
