hyfyve's avatar
hyfyve
Hardwiring inverter to converter and redundant charging
I am thinking of adding dual 6 volts and a solar charger with inverter system to my open range, I have a question about 12 volt charging.
The inverter I was looking at has a built in switch and also a battery charger.
The converter that's in my RV now has a 12 volt distribution fused block.
I want to wire my inverter with switch to my converter so I can run my whole trailer on the batteries if I do not have shore power. The batteries of course need to be connected, therefore when I do have shore power the inverter will charge my batteries and transfer 120 VAC to my converter.
My converter also has a charger and all the 12 volt is distributed through it, so when the converter is getting 120 VAC it is also charging the batteries.
Therefore when I am connected to shore power my inverter will be charging the batteries and the converter will also be charging.
Is there any issue with this sort of loop? Hope this makes sense I have attached a picture to better explain myself. Thanks.
Edit: just a thought but when I am not plugged into shore power the inverter will be feeding power to my converter therefore would I have power to my 12 volt distribution and if so could I disconnect the cables from my battery to the converter?
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
