Gordon1152's avatar
Gordon1152
Has anybody ... ?
This is my second coach and the second camera system and MDVR that I've installed, but I'm baffled by what the current system is doing. If I select the main display to be the rear camera (to watch the toad and approaching traffic), when I trigger the turn signals the screen goes black ...
BUT WAIT THERE'S MORE: I just figured out today, if I set the main display to be a quad view everything works as it should ... BUT I DON'T WANT TO LOOK AT FOUR CAMERAS ON A 7" SCREEN ...
Has anybody ...?
  • Thanks rlw999! Actually I removed a camera switching system that was OE (Voyager connections ... I hate Voyager/ASA systems) and there was a trigger connector right there (one for reverse and one each for the sides), so that was a no-brainer ...
  • Since you installed it yourself, this seems unlikely, but it seems like it's sensing the turn signal and trying to switch to a non-existent side view camera.
    But you'd have had to hook up turn-signal sensing wires for this to happen (unless you plugged into some OEM wireing harness that included turn signal sensing).
  • Thanks cougar28! The cameras are powered in the dash by the MDVR ...
  • Is the camera powered by a clearance light that blinks with the turn signal? That would be about the only thing I could think of.
