dougrainer
May 12, 2016Nomad
Defrost heaters do not run that much. In the OLD refer mechanical control's, the defrost heaters were on a mechanical timer. In the newer electronic control refers, I would bet it is on a temp sensor control instead of a timer, but you need to find out. The purpose of the defrost heaters is to remove the ice buildup from the evaporator/s. The ice restricts the air flow thru the evap fins and causes a loss of cooling in the refer. So, if you turn the Heaters OFF, you may cause a faster ice build up and that would cause the refer to run LONGER to maintain your temp. So, it would be a trade off on power consumption----either the defrost heater would run or the compressor would run longer due to the defrost heater not removing the ice build up. Doug
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
