enblethen
Nov 10, 2017Nomad
I install 1/4 inch quick connects on the ground wire. Bought terminal to go where spade would be normally.
Used female like these. Yellow connector
Used one similar to this on genset. Had to drill hole for screw to fit through.
Genset side
For bonding the genset, use a male three wire plug. Jumper between neutral and ground pins.
Genset side
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
