Bobbo's avatar
Bobbo
Explorer III
Nov 11, 2017
Have a question for the electrical gurus.
I have a Honda EU2000i generator, and am thinking of getting a Companion and paralleling them. I don't like the GROUND wire that is on the paralleling kit because it takes a screwdriver to attach. Is there a problem with buying a pair of male plugs and wiring only the GROUND pins together to plug into the 20 amp outlets on the generators? There would be no wires, whatsoever, connecting the other prongs between the two plugs.
(Although, I have to have a bonding plug because of my PI EMS-HW30C, so I will run that same ground wire to one of the NEUTRAL pins. That will make it a GROUND connector/bonding plug combo.)
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 22, 2025
