Leeski_Clan
May 13, 2018Explorer
SoundGuy wrote:Leeski Clan wrote:
I installed a GoPower IC 3000 which is an inverter, charger and transfer switch combo unit.
In testing, I first ran the TV which pulled ~1.5 A. Then I ran the Norcold 2118 refrigerator and according to the GoPower monitor, the Amp draw went from 1.5A to 48A!
Your new Norcold 2118 is a 2-way gas absorption fridge designed to automatically switch over to run on gas when shore power isn't available so why would you attempt to run it on an inverter? :h Specs, including current draw, are included in the specs I linked to.
I was just testing the Inverter / Solar system. I'd normally run the fridge off of propane but switched over to inverter to test the inverter. I had no idea that it would draw that much amps. I thought there may be a problem as the Norcold site says it draws 6 amps.
I guess this is the normal draw for that fridge.... dunno.. see my comment above regarding Charlie Brown's teacher.
Thanks for all of your advice.
Happy Camping!
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
