BFL13
May 13, 2018Explorer II
Leeski Clan wrote:time2roll wrote:
I call normal for an absorption fridge. Set the fridge to propane only while using the inverter. Or is this a compressor fridge?
Actually mine draws about 30 amps so I assume yours has more features. You want to see some real amps... put the water heater on ;)
I would recommend 600+ amp hours battery for a 3000 watt inverted.
This is a propane electrical fridge. Norcold 2118.
I have 4 x 6v @ 210 Ah each so I have 800+ Ah.
Two 6s in series make 210 and another pair in parallel with them makes for 420AH.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
