garyemunson
May 13, 2018Explorer II
The 6 amps is the 120 volt AC value. Your inverter needs A LOT more amps than that at 12 volts DC to provide the 120 volts/6 amps A/C. Just like Leeski posted! Use the inverter to power the fridge when you are driving (engine will keep batteries charged) but as soon as you park, if you are not going to plug into shore power, switch to propane and save your batteries.
