TheBeans's avatar
TheBeans
Heat & A/C on at the same time!
My SIL just bought a used 5th wheel. When she recently went to turn on the heat she noticed immediately that the heat AND the a/c came on together and they were both blowing from the vents in the roof....no heat coming out of anything near the floor!
What would cause something like this to happen and has it happened to anyone else? Where should she begin to look to figure out what is going on here?
  • jdc1's avatar
    jdc1
    Explorer II
    How can you both heat and cold from the same vent? LOL. See the above last line/
  • My new FW will allow me to set the heat and AC at the same time. The theory is that if you were to be away all day and it's cold in the am but hot in the afternoon, the heat can run to bring it to temp X and the AC to temp Y. If the temps were set to be the same, I guess it's possible they could both come on at the same time since they are independent systems. They don't use the same ducts however.
    I guess questions would be how did she know both were on ? Was there a panel that told her this? And how did she know they both came out of the same duct? Does she have a heat pump in her AC unit?
    It is possible that the ducts could have held hot air when the AC turned on and felt warm until the ducts cooled?
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
