BFL13
Jul 08, 2014Explorer II
Heat 1, MPPT 0
Previously we noted that heat is hard on MPPT due to the panel's loss of voltage with increasing heat. Doesn't bother PWM though, you still get Isc or more. This Spring, I took some measurements p...
MrWizard wrote:
If the panels get so hot the voltage is low, the MPPT should be passing the amps straight thru
