BFL13's avatar
BFL13
Explorer II
Jul 08, 2014
Heat 1, MPPT 0
Previously we noted that heat is hard on MPPT due to the panel's loss of voltage with increasing heat. Doesn't bother PWM though, you still get Isc or more.
This Spring, I took some measurements posting the MPPT vs PWM values, and at high noon was getting about 15.5 amps vs 14.5 for PWM.
The thought then was when it warmed up for Summer the MPPT "advantage" would not be even that much. So here we are in some hot weather (for here) so a comparison was made.
I have been noticing lately that the expected amps just aren't coming in and wondered what was the matter. Checked everything, nothing found wrong, then measured temp under panel. Oops.
So here are the Spring/Today figures in blue sky no clouds all same set-up.
Ambient temp- 16C/24C
Under panel temp- 44C/48C
Voc-35.4/34.0
Isc- 8.7/8.4
Amps output 15.71/13.88 (both at 13v battery)
Panel watts (of 230w)- 205/181
So instead of getting 1 amp more than PWM, now I am getting 1 amp less than PWM for my 230w. It seems the only difference in conditions is the temperature. The under panel temp is not that much more compared with the big jump in ambient, but it is enough to hurt the MPPT.
BTW, panel voltage coefficient is - 0.330%/degree C. Rated Voc is 36.8v got 34, diff is 2.8. Temp diff is 48-25C = 23 and 23 x .33 is 7.6 and 7.6% of 36.8v (rated Voc) = 2.8v and that minus 36.8 is 34, which us what I got for Voc so that all works out.
Bottom line us that MPPT sucks unless you use it in the Arctic :) I would do better with two 115w panels than with the single 230w. Fortunately, with the warm weather there is also no furnace to run, so the loss in solar doesn't matter, but I still get annoyed when I don't get those amps in whether I need them or not! Drat and phooey!
I can't even complain that this is a surprise, since I used to post about that before I got this set-up. I got it because the price of the 230 was better than two 115s. Now I am paying the other "price" in aggravation.
  • I am not complaining about this great weather this week on the East side of the Island! Too bad if the stupid solar wilts. : )
    I am not sure about that 1% over 44C in view of the math that came out right in the OP on the voltage coefficient. However that is only the 44-48 part of the 25-48 so maybe it doesn't show enough in there.
    Of course there are many good reasons to choose 24v panels over 12v panels and that means you need an MPPT controller if you go 24
    Just that nobody should expect the often mentioned greater daily AH haul you supposedly get with MPPT as a reason to get MPPT. As seen in my various comparison tests as posted in the past few months, that diff in AH haul is tiny if you even get any. Only get MPPT if forced to go 24v for other reasons IMO.
  • Almot's avatar
    Almot
    Explorer III
    BFL13 wrote:
    I had the idea you had to be in Death Valley or someplace to really notice that loss of amps.
    Apparently, the Death Valley for PV begins around 44C. You're losing Vmp at the rate of 1% per C degree. In case of MPPT it means - losing amps. In case of PWM it means nothing, until volts at the battery end drop below Absorb, and then you can't get a full charge.
  • The comparison is made with the same controller and the rest of the set-up the same so we don't need to speculate about how a different controller might do instead. I don't know if the controller's temperature compensation (internal, not remote to battery) matters. AFAIK that just affects the set-points. The controller is in the shade in a compartment with the door open lots of air.
    I have used PWM set-ups in the same location at these same high temperatures with no loss of amps. The 12v panel does also have lower voltage in the heat (20.3 vs 21.9 rated typically) but the Isc actually rises (positive coefficient) and I get Isc as the output.
    So the comparison with PWM is under the same conditions. What I find surprising is how the MPPT amps are less with just that much heat (24C ambient). I had the idea you had to be in Death Valley or someplace to really notice that loss of amps.
  • Almot's avatar
    Almot
    Explorer III
    There was a study that once the panel reached 44C, its output in watts drops not by 0.3%, but by 1% per each C degree. If I understand correctly, it's voltage that drops. Perhaps not much to worry with BC weather, as it rarely gets ridiculously hot there, but with PWM, when it gets really hot, you would have Vmp below 15V, not to mention voltage drop in wires. OTH, with MPPT in the same scenario you would get wattage drop, i.e. lost amps and amp-hours, which sounds like lesser of two evils.
    It's also possible that your controller's V/A conversion doesn't work too well.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
