DiskDoctr
Jul 10, 2014Explorer
Is your infloor radiate heater turned off? :)
Seriously, though, the tires will be hot, the exhaust is hot, drive train, etc. The asphalt/ground is probably hot from the sun before you parked there.
I bet if you crawled underneath and CAREFULLY felt around with your hand (in the air, not actually touching anything), you'll find the spot with the most heat.
Heat shields and such can help, but if there isn't air moving over the area, it must eventually radiate upwards.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
