JayNewbieRV
Dec 13, 2024Nomad
Heat gauge
I have a 2007 Winnebago view 23J Dodge Springer chassis. In the summertime when I’m traveling the heat Gauge gets close to red line if I’m running the AC; when I turn the AC off, there’s not a prob...
Welcome. Overheating with the AC on sounds like a problem with the condenser fan. The condenser fan is responsible for cooling the air conditioning condenser, which heats up when the AC is on. If the condenser fan is not working properly, the condenser will overheat, and this can cause the engine to overheat as well. I think it was a fairly common problem on the Dodge and MB sprinters a while back.
I appreciate your quick response and the information, thank you so much!!!
So what is the solution to that, do I need to get a new fan, or is there a way to get that tested???
Upon getting my radiator flushed, the guy at the shop said the fan may be the problem and I may need to install a different kind of fan???
any solutions would be much appreciated.!!!🙏
once again thanks for your response.
