SteveRuff
Oct 24, 2013Explorer
I use my heat pump 98% of the time because I try very hard to stay where it doesn't freeze often. That being said, when an overnight freezer is forecast I will use my propane heater because it also pumps heat through the vents on the floor rather than through the air conditioner vents in the ceiling. This helps prevent pipes from freezing as well since the heat is lower and heats the lockers somewhat.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 06, 2026
