a64armt
Oct 24, 2013Explorer
SteveRuff wrote:
I use my heat pump 98% of the time because I try very hard to stay where it doesn't freeze often. That being said, when an overnight freezer is forecast I will use my propane heater because it also pumps heat through the vents on the floor rather than through the air conditioner vents in the ceiling. This helps prevent pipes from freezing as well since the heat is lower and heats the lockers somewhat.
Very good tip, I will have to remember that. Most of the 5er's we are looking at have roof vents with their AC/heat pumps. Never thought that the basement wouldn't see much of that heat.
Thanks,
OJ
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 06, 2026
