RVUSA
Jan 11, 2014Explorer
Maximum Temperature
Setting too high can scald someone using the water. This is particularly easy because when you first open the tap, the water in the pipes has cooled down some, and so its temperature will raise (possibly dramatically) once the water from the tank reaches the point of use. Young children are at higher risk because their skin is thinner. Some people, especially the elderly, are at higher risk because they may be less sensitive and slower to move away from scalding water.The Consumer Product Safety Commission (CPSC) recommends setting to 49 °C (120 °F).
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
