westend
Jan 11, 2014Explorer
The problem with an RV is where does the heat pump scavenge the warm air to heat the water heater? It may be that you are lowering that hard-fought interior temp of the cabin to heat the water. There would definitely be connection issues with this device in an RV, as well.
Heat pumps and residential 40+ gallon tanks are a pretty good fit, especially if the heater is electric. If an owner has Natural Gas water heating and a damp basement, it can also work well as the heat pump acts as a dehumidifier, too. Payback on electric residential water heaters can be as short as 3-5 yrs. Gas water heaters will have a much longer payback on the heat pump. Coupling a heat pump with whole house geothermal to serve both forced air and water heating makes a whole lot more sense and most Mfg's of geothermal solutions are rolling out the auxiliary use for heating water.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
