CA_Traveler
Sep 24, 2019Explorer III
joebedford wrote:X2 Similar setup. One circuit can be easily used with an extension cord when using a 30A pedestal.CA Traveler wrote:Agreed. However, I got nervous about running 1500W through a cheap RV receptacle because the plugs were heating up (probably the receptacles), so I installed 2 dedicated circuits with residential receptacles. Now I can run 2 ceramics to without worry.
Small ceramic heaters are cheap and quiet.
Not only are my Monaco receptacles "cheap" the primary usable ones are on a single inverter output and there are "only" 14 plugs on that circuit.
