Almot's avatar
Almot
Explorer III
May 24, 2023
Heated mat?
Something like this: 110V, 730W, 5x2ft. Did anybody use it? When you have a grid power and morning temps inside are in mid 50s (12C). Near floor it's a few degrees cooler. Thick duvet keeps me toasty but need all my willpower to get out of the bed in the morning. It gets warmer when the sun goes up, but need to stand/walk for an hour while making breakfast. Small trailer, main habitat is the 6x2 ft "corridor" btw the table and kitchen counter, with a coach on one end and toilet on another. Looks like the place for a 5ft mat.
Or maybe put a space heater with fan, they usually have a power regulator: 750-1500W space heater. "Thermostat" is a BS, I suspect. At best it would measure the casing temperature and work on-off in either 750 or 1500W mode. Would love to have a real wall thermostat like in shore home.
  • Your post brings all sorts of issues to mind. First if you have an electric hook up, why are you suffering with a cold RV? Why are you not using a space heater? Second, when you get up in the morning, why not use your furnace? Mine does a good job in a few minutes.
    This is a separate issue, but I cannot imagine spending an hour making breakfast. Coffee and oatmeal just require some boiling water. Eggs are even quicker.
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 14, 2025
