Fixed_Sight_Tra
Nov 27, 2016Explorer
BobsYourUncle wrote:
I might be a long shot but I had a similar situation once a few years back.
Turned out that when I filled the bottle and put it back on I somehow managed to trigger the built in shutoff in the manner I hooked it up and turned the valve on. There was flow but not much.
My solution was to disconnect the tank, hook it back up and slowly open the valve.
Worth a try I guess.
Tried this and it worked. I thought lighting a burner would do essentially the same thing but I was wrong. It still doesn't seem to be as hot as usual. I think I'll take a compressor out and blow it out and see if it has some dust built up inside.
Thanks for the advise.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
