dougrainer wrote:
mikestock wrote:
This may not work but it is easy to try:
(1) Turn off the gas at the tank or both tanks if you have two.
(2) Bleed all of the gas from the line by attempting to light a stove.
(3) Make sure all gas using points are off and there is no demand.
(4) Turn the gas back on at the tanks while keeping all appliances off.
This should allow the regulator to reset.
I've never had this happen in the RV but have seen this work with a gas grill regulator that is starving the burners.
There is no such thing as "resetting" a RV LP regulator. What you outlined would be because the short Pigtails from the DOT tanks to the LP regulator have "jammed". Releasing the pressure in your scenario will allow the Hi pressure pigtails to indeed reset. Doug
Thanks. As I said, I could not claim that this would work on an RV system. I just thought it was worth a shot and not too hard to try.
