NinerBikes
Apr 05, 2016Explorer
dougrainer wrote:
RV absorbsion refers do NOT run on 12 volts. They only require milliamps 12 volt to run the controls. 3 way RV refers are NOT designed to be run camping on 12 volt. You MUST have a Truck or hi output charging system to run a 3 way on the 12 volt Heat Element. The 3 way 12 volt heat element is designed to only KEEP the existing temp in the refer and not to cool it down to temp. Doug
/\ That is a goldmine nugget that confirmed what I always thought.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
