dougrainer
Apr 06, 2016Nomad
valhalla360 wrote:dougrainer wrote:valhalla360 wrote:dougrainer wrote:valhalla360 wrote:
I'm confused. Gas fridges in an RV forum typically refer to ammonia absorption models that have no Freon.
I think most compressor based (typical of household units) no longer use Freon.
Gas fridges in electric mode aren't that efficient but they typically are only run in electric mode when in a campground with power available so it's not a big concern since electric generally comes with the site. If you try to run them off battery power...it's just silly as the reason for using gas unit is the ability to not use electricity when dry camping.
There is NO difference between 120 ac mode and LP gas mode in cooling. BOTH have almost identical BTU heat output. Doug
Sure but I never suggested otherwise.
Efficiency was in comparison of an ammonia absorption vs a compressor based if both run on electricity. A good compressor based unit will be more efficient but if you are hooked up to shore power which is already included in the cost of your site, most people don't really care.
But if you are away from shorepower, trying to run an absorption fridge off a battery bank and/or solar panels, gets impractical. Even more so in comparison to a compressor based unit.
RV absorbsion refers do NOT run on 12 volts. They only require milliamps 12 volt to run the controls. 3 way RV refers are NOT designed to be run camping on 12 volt. You MUST have a Truck or hi output charging system to run a 3 way on the 12 volt Heat Element. The 3 way 12 volt heat element is designed to only KEEP the existing temp in the refer and not to cool it down to temp. Doug
Sorry but some DO have the option to run on 12v or you can use an inverter to access the battery power if you don't have 12v heater option.
But due to the efficiency, if you plan to use 12v regularly, a compressor based unit makes a lot more sense.
You are absolutely WRONG. RV Absorbsion refers that have a 12 volt Heat Element are for in Transit only power. The 12 volt heat element will drain any battery bank in less than 8 hours. There is a difference between ABSORBSION 12 volt and a 120/12 volt RV compressor type unit. Doug Below from the Dometic manual.
Mode 3 Way Units Only
Press the DC mode indicator button 2 to the DOWN position. Lamp A will light. Press the TEMPERATURE SELECTOR button 4 until the lamp F at the desired position is illuminated. The refrigerator will continue to operate in the DC mode until switch 2 is moved to the UP position or control voltage falls below 9.6 VDC. The DC mode overrides all the other operating modes. Discharging of the battery will occur if the vehicle engine is not running.
Note The DC mode is a holding mode not a full cooling mode. DC should be used once the unit is cooled down and constant supply of DC available driving down the road.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
