MEXICOWANDERER
Apr 06, 2016Explorer
Hmmm I seem to remember the figure 1.15 amps for the Norcold. 'Course that can be expressed as 1,150 ma.
The sole heat-to-cold device that I still respect is a lithium bromide absorbsion chiller. Even then the entering stream temperature had to be monitored hourly to avoid the lithium bromide from dropping out of solution.
On a hundred degree day I would start out at dawn with a 35 degree Norcold then switch it to gas. At 6:30 I would arrive at my destination and the 12-volt element provided a bone numbing 47F. Ten degrees above correct temperature using wattage that would have successfully maintained a 17 CF chest freezer at -5F
BOTH Vestfrost units together use LESS energy than the Norcold. The penalty was in the price and the weight.
Installed 1985. Never touched since.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
